2004 Dodge Intrepid Car Starting
JACKIEM
Computer problem
2004 Dodge Intrepid 6 cyl Automatic 87,000 miles
I have an issue with my Dodge Intrepid. My check engine light is on and I am having problems with starting my car. 9 times out of 10, the car will start fine and run great. However, it will not start once in a while. Sometimes, it will try to turn over and doesn't. Sometimes, it only clicks. I can disconnect my negative battery cable and wait for a few minutes and the car will ususally crack right up. Or you can do nothing and wait for a few minutes or a hour, and the car will crank right up like nothing ever happened. The problem seems to be getting worse. Now I have had it die on me at an intersection while I was stopped at a red light. It started up again but then died 100 yards later when I was pulling into a parking place. I bought the car about 1 year ago with 80,000 and have never owned a Dodge before. With no car history, I am at a loss. I took it to Auto Zone and got 3 different error codes off of it, PO344, PO440 and PO442. I have been told that the camshaft sensor is the issue or it could be a bad fuel cap, EVAP canister or hose is bad, purge or vent solenoid is bad or I have a vacumm leak. I have NOT got the money to take it to a dealership. And computerized cars are over my head. HELP!
Dec 7, 2008 at 2:02 AM
  • 110,251 POSTS
Hi:
Based on what you mentioned, the only thing that could cause this type of problem would be the crank sensor. The EVAP system shouldn't cause these problems.
Dec 8, 2008 at 4:52 AM
JACKIEM
Where is the camshaft senson? Is there a diagram that I can use to locate it and a recommendation on th procedures to change it?
Thanks,Jackie
Dec 8, 2008 at 2:06 PM
  • 110,251 POSTS
I believe it is on the front timing cover, left side, middle.
Dec 9, 2008 at 12:03 AM
