2004 Dodge Intrepid Broken PVC Hose??
DEADPLASMACELL
  • 11 POSTS
Engine Cooling problem
2004 Dodge Intrepid Automatic 75,000 miles
Hi, again, I've run into an issue with our Intrepid, we took our car in for an Oil change at the beginning of last week and when we got the invoice there was a note that said "PVC hose broken" we didn't notice the note until we looked at the invoice a few days later while we were filing it, we called them up and asked them about it and he said it was cracked and it could break any time now and it would be about $80 to fix (P&L). I changed the air filter this past Friday night and the first thing I noticed is that the coolant was very low, about a quarter inch below the minimum line. I then looked around and saw what I thought was the hose he was talking about, it's broken in half it seems. There was a chunk sitting on top of the motor casing, it's about an inch or so big and feels pretty brittle. Anyways, we've been driving around with it like that for who knows how long.. Friday through today for sure, but we haven't noticed anything different, the car temp is normal and there are no warning lights on or anything. So I guess my questions are 1) Does this seem like the hose our Mech. may have been talking about? 2) we can't really take the car in until Wednesday, so you think we're safe until then? It seems like it's connected to the coolant tank.
Thanks for any help!
May 18, 2008 at 11:04 AM
  • 75,988 POSTS
Plug both openings you'll be fine till wednesday
May 18, 2008 at 11:25 AM
DEADPLASMACELL
  • 11 POSTS
Thanks for the quick response! Sorry to sound dumb, but what exactly would I plug it with??
May 18, 2008 at 11:31 AM
  • 75,988 POSTS
Stick a plastic material in it and clay for the time being especially the valve end-
May 18, 2008 at 10:13 PM
DEADPLASMACELL
  • 11 POSTS
Alright, will do.. Just for my general knowledge, what exactly does that part do? Seems like it has to do with the coolant tank, but I'm not sure.
May 18, 2008 at 11:07 PM
  • 75,988 POSTS
Its a flow control valve to regulate airflow and also prevent crankcase oil from being pulled into the manifold. It prevents pressure build up in the crankcase
May 19, 2008 at 2:58 AM
