2004 Dodge Intrepid
KRCHARLE2
  • 2004 DODGE INTREPID
  • 6 CYL
  • FWD
  • 111,584 MILES
Water housing in front of plenum bad need to replace. Need to remove plenum in order to replace water housing do I need to depressurize fuel before removing plenum
Tuesday, August 11th, 2009 AT 12:56 AM
BMRFIXIT
  • 19,053 POSTS
STANDARD PROCEDURE - FUEL SYSTEM PRESSURE RELEASE PROCEDURE
Remove Fuel Pump relay from Power Distribution Center (PDC).
Start and run engine until it stalls.
Attempt restarting engine until it will no longer run.
Turn ignition key to OFF position.
Return fuel pump relay to PDC.
Tuesday, August 11th, 2009 AT 5:34 AM
