2003 Dodge Intrepid Radiator Fans
112,006 MILES • 6 CYL • FWD • AUTOMATIC
RAYNW2004
  • 6 POSTS
I had my radiator fans replace two times already. The shop did some wiring work. My car has been doing fine for about two weeks now. Today I turned it off and it is making that noise before the radiator fans failed last time. Do you know what keeps causing them to fail
Jun 2, 2010 at 9:30 AM
BLUELIGHTNIN6
  • 16,542 POSTS
what type of noise is it making and where is the noise coming from
Jun 2, 2010 at 1:49 PM
RAYNW2004
  • 6 POSTS
its coming from the front part of the engine. It makes a growling noise
Jun 2, 2010 at 1:50 PM
BLUELIGHTNIN6
  • 16,542 POSTS
check the coolant level in the radiator. does the coolant temp. gauge show overheating? seems like engine may be overheating causing fans to overwork , growling may be from coolant boiling in radiator.
Jun 2, 2010 at 1:52 PM
RAYNW2004
  • 6 POSTS
The temp gauge stays at its normal level. Im not sure exactly where the radiator fluid is on my 03 2.7 liter
Jun 2, 2010 at 1:54 PM
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_2305.jpg
Jun 2, 2010 at 2:03 PM
RAYNW2004
  • 6 POSTS
yep i check all of it its fine. The guys at the shop said its some electrical problem and they replaced my relay ans it burned out again
Jun 2, 2010 at 2:05 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Ok, if it's already been pinpointed to an electrical issue and you say the wiring and relay have been replaced then I would suspect a bad powertrain control module (PCM). it is the vehicle's computer and could be sending wrong signal making more volts go to fans than should be, which will burn out the system quickly.
Jun 2, 2010 at 2:07 PM
RAYNW2004
  • 6 POSTS
so where can i have that checked out? also is it easy to do myself? Thanks so much
Jun 2, 2010 at 2:09 PM
BLUELIGHTNIN6
  • 16,542 POSTS
unfortunately really no way to test the PCM, just have to swap with a known good one and see if it cures problem. it's just a box with a few connectors plugged into it as far as replacing it yourself..
Jun 2, 2010 at 2:12 PM
RAYNW2004
  • 6 POSTS
thanks so much
Jun 2, 2010 at 2:15 PM
