2003 Dodge Intrepid oil light
71,000 MILES • 6 CYL • FWD • AUTOMATIC
BSTEALEY
The oil light comes on while I am at a stop but goes off after I start driving. I just got an oil change and checked the oil level to make that was okay.
Jan 23, 2009 at 4:25 AM
  • 75,988 POSTS
Use a mechanical gauge and check oil pressure thru the oil pressure switch if normal readings obtained replace the oil pressure switch if not could be oil pump and engine bearings etc-
Jan 23, 2009 at 4:32 AM
