2003 Dodge Intrepid interior lights on panel
25,000 MILES • 4 CYL • FWD • AUTOMATIC
M.J. GLEICH
The lights on the odometer and radio will dim/flash when the engine runs and the headlights are on. No other lights dim/flash, just these lights. The problem happens only when the headlights are turned on.
Thanks for your help!
Nov 11, 2008 at 3:23 AM
  • 110,248 POSTS
Hi:
Check under the dash to make sure none of the plugs are loose. If they are ok, it's most likely a ground problem.
Nov 11, 2008 at 12:49 PM
