2003 Dodge Intrepid car hesitates and losses power
110,000 MILES • 6 CYL • FWD • AUTOMATIC
LILBEARS
first starting car it starts and does fine for a minute then it losses power. the rpms drop to nothing and when you press the gas pettle down it does nothing. No reving no nothing. then it backfires and a minute later its fine. there is no warning lights and also no codes. PLEASE HELP
Apr 14, 2009 at 7:51 AM
CARADIODOC
  • 34,403 POSTS
Impossible to say without further testing, but as an educated guess, you might try a different MAP sensor. It affects fuel metering based on engine load. The voltage reading must be outside specific parameters to set a diagnostic fault code and turn on the "Check Engine" light, but as long as it's within acceptable limits, an incorrect reading will have a big impact on engine performance.
caradiodoc
Apr 15, 2009 at 6:10 PM
