how do you take off the door panel? My window is off track and it is 15 degrees.
Jan 20, 2009 at 8:34 AM
✓Experienced Mechanic
Hi:
The door panel is held on by a few screws and clips. Locate and remove the screws. Then carefully so you don't cause damage, pull the panel away from the door disconnecting the clips.
