2003 Dodge Intrepid
101,000 MILES • 6 CYL • FWD • AUTOMATIC
WMASSEY
There is a small hole located just below the thermostat housing that is leaking water. Is this a sign that the water pump is bad?
Jun 20, 2009 at 7:26 AM
  • 110,248 POSTS
Is the hole on the pump? Is it a hole that was designed in or is something cracked or broken? If it is on the pump and appears that it should be there, chances are the seal / bearing in the water pump is going bad. THat is a seap hole that is used to identify when the seal is leaking.
Jun 20, 2009 at 3:53 PM
