2002 intrepid
M YBARGUEN
i have a 2002 dodge intrepid that has 84,000 miles. the problem that i am having is when i am stoped at a stop light or just ideling the oil light will come on very dim. i have checked the oil level and it is fine. as soon as i push on the gas the light goes off. could it be a clogged oil filter, or is the oil pump going out?
Apr 13, 2006 at 4:41 AM
BABYBOOMER
Same problem with a 2000, 2.7...light comes on at idle, oil is full and clean...anyone have a solution?
Thanks
Apr 29, 2006 at 1:44 PM
32INTREPID
This is caused by a bad oil pressure switch. Its a common problem with these. Rare cases have low oil pressure.
May 13, 2006 at 3:16 AM
