Fault code P0633. Vehicle won't crank.
MOODYNURSE04
Electrical problem
2002 Dodge Intrepid 6 cyl Wheel Drive Type unknown Automatic 70,000 miles
my dodge intrepid 2002 wont crank after I left light's on, charged battery & lights etc. work fine now, just wont turn over. fault code is P0633, do you know what this code means, or what the problem might be? thank you, gina
Jan 22, 2008 at 9:45 AM
  • 75,988 POSTS
It means Immobilizer Key Not Programmed – ECM/PCM check with your dealer. Hope that helps.
Jan 22, 2008 at 10:24 AM
MOODYNURSE04
Thanks.
Jan 22, 2008 at 3:53 PM
