2002 Dodge Intrepid water pump
84,000 MILES • 6 CYL • 2WD • AUTOMATIC
KENNETH.ODEM1
need to know where the water pump is located on a 2002 dodge intrepid
Oct 28, 2008 at 9:39 AM
  • 110,248 POSTS
Hi:
The waterpump is behind the timing belt cover. It is driven by the timing belt. If you go to the section titled "Popular Site Links" and select "Drive belt Routing Diagrams," and put in your car's information, you will see a diagram of the timing belt and it identifies the waterpump.
I hope this helps. If you have any other questions, let me know.
Positive feedback is appreciated.
Nov 4, 2008 at 5:26 AM
