2002 Dodge Intrepid water draining from evaporator vent tub
BYRON4321
Engine Cooling problem
2002 Dodge Intrepid 4 cyl Front Wheel Drive Automatic 100k miles
I have to constantly add water to my car. After crawling underneath it, I found water draining from my evaporator vent line. I know this is normal (condensation) when the A/C is running, but it is just short of pouring out and the A/C is not running. Also there is air blowing from the tube (even when the heater/AC fan motor is not on) - not sure if this is normal. Anyways, I am leaning towards thinking the heater core is leaking, but wanted to ask around before diving into that project.
Oct 17, 2009 at 11:17 AM
BMRFIXIT
  • 19,053 POSTS
Coolant system pressure test should reveal the fault or the leak
are you adding coolant antifreeze or just water
place the heater on defrost and turn it on does the windshield fogs
Oct 17, 2009 at 12:01 PM
