2002 Dodge Intrepid Transmission Kicks in 1st gear
MINICO
  • 2002 DODGE INTREPID
Transmission problem
2002 Dodge Intrepid 6 cyl Two Wheel Drive Automatic 271400 km
Tranny drops in first gear at intersection when slowing down. If I stop & restart the car its ok until I slow down again. Transmission Fault P1773, Solonoid switch latch in low gear.
Monday, May 12th, 2008 AT 12:25 PM
MASTERTECHTIM
  • 4,750 POSTS
Have you checked the solenoid? Shift solenoids fail causing shift problems. I check them with a ohm meter and check resistance and then use a power probe to supply voltage and ground to them and see if I can hear them click. You might want to take it to a tranny shop to have them hook up the scanner to it, they can command solenoids on and off without taking transmission apart. Hope this helps
Friday, May 30th, 2008 AT 12:03 PM
