2002 Dodge Intrepid Thermostat problems
2002 DODGE INTREPID
122,000 MILES • 6 CYL • 2WD • AUTOMATIC
LESPAULGTR_79
Can somebody explain where to find the thermostat on an 02 intrepid 3.2L, and whats the easiest way to get to it?
Jul 2, 2009 at 3:54 PM
Under the vehicle, drivers side.
1.. Disconnect negative cable from remote jumper terminal.
2.. Drain cooling system
3.. Remove the engine oil dipstick and tube. To prevent coolant from
entering engine, cover the dipstick tube opening in crankcase with a
suitable plug.
4.. Raise vehicle on hoist.
5.. Support the engine and remove the left engine mount
6.. Remove generator support strut.
7.. Disconnect generator electrical connector.
8.. Remove the transaxle dipstick tube bracket attaching bolt.
9.. Remove the lower heater hose tube bracket bolt.
10.. Remove the lower heater hose from thermostat housing.
11.. Remove radiator lower hose from thermostat housing.
12.. Remove thermostat housing bolts
13.. Remove thermostat and housing.
Jul 4, 2009 at 1:55 PM
