2002 Dodge Intrepid P0563 code
2002 DODGE INTREPID
120,000 MILES • 6 CYL • FWD • AUTOMATIC
STEVE10069876
The code keeps coming on. I have replaced the alternator twice in a week. the odometer flickers. placing the vehicle on an meter the voltage jumps between 12 to 15.5 volts. normally not at idle but when rpm is raised. the above code remains. Battery was checked and good. connections checked and good. Everything points to a bad alternator but after replacing with two brand new ones I dont think this is the problem,
Sep 22, 2010 at 6:12 AM
  • 110,244 POSTS
Have you checked for bad fuseable links?
Oct 6, 2010 at 4:20 AM
