today we had the ignition switch replaced which cured the problem with the AC not coming on and the air bag light staying lit.
The car still overheats, I noticed that the drivers side fan is not running even though the engine was very hot.
What do I do now?
Update: I found the problem: When the ignition switch went bad I would wiggle the key to get the air bag light to go out and for the AC and fan to start running, in wiggling the key it must have caused a surge and the fuse for the fan relay blew. I did not check the fuse (I feel dumb to admit it) because the car had been in the shop the week before because of the overheating problem and I thought that the fuses must be OK. I think I will stick to my day job.
By the way, the ignition switch would cause the car to run rough, the air bag light would stay on, the AC and fan would not work, the windows would not go up or down, and sometime while driving the car would lose all power and everything would work again after I wiggled the key. If anyone has these problems a $55.00 part may fix it.
SPONSORED LINKS
Saturday, October 10th, 2009 AT 2:58 PM
