2002 Dodge Intrepid nothing works when the car is off
MIKENIKE42
Electrical problem
2002 Dodge Intrepid Front Wheel Drive Automatic
When the car is on all of the electrical components work fine but when the car is of the remote lock doesn't work, the regular door locks do not work, and none of the reading or overhead lights lights work when you open the doors. These are all things that should be functional when the car is off. What are some of the areas that I should check?
Aug 26, 2009 at 12:43 AM
JDL
  • 16,098 POSTS
Hello, check fuse 19--15 amp. The fuse circuit should be hot all the time. Not only check the fuse, check that the circuit has voltage.
Aug 26, 2009 at 1:21 AM
