2002 Dodge Intrepid Making a knocking noise
16,000 MILES • 6 CYL • FWD • AUTOMATIC
AMYJO
I am trying to figure out what is going on with the front end of my car. Whenever I make a left hand turn and then apply the brakes it makes a knocking noise, coming from I think the driver side front wheel (although sometimes it sounds like different places).
Anyway it only happens once, and does not happen again until another left hand turn is made. I took the tires off, checked the brakes, etc. Everything looks ok. Not sure what could be causing it? CV Joint? Tie Rod End??
Just seems odd that it only does this one time.
Jan 21, 2010 at 12:35 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Have lower ball joint checked also lower control arm bushings.
THanks for donate
Jan 21, 2010 at 3:20 AM
