2002 Dodge Intrepid low to mid rpm rough running
2002 DODGE INTREPID
25,000 MILES • 6 CYL • FWD • AUTOMATIC
RIGGERR1
Hi, My 2002 Dodge Intrepid has a 2.7 liter V6 with 250,000 miles on it. At low and mid range RPM it runs rough- stalls out sometimes, and engine light comes on and sometimes flashes. If I press accelerator to the floor the car just takes off and goes GREAT!, but anything less than full throttle it just runs really rough. Dealer can't find a problem. oxygen sensors are new, catalytic converters are new, compression on all cylinders is good, computer is new,1 coil was replaced (each cylinder has it's own coil), and injectors are new. Engine code was checked and came back as catalyst insufficiency, and 02 sensors 1 and 2, but like i said they were replaced. Please help?!
Apr 10, 2008 at 3:07 AM
BMRFIXIT
  • 19,053 POSTS
all this work was done and no one checked for codes
check engine light on and flashes
1st step is to check for codes
Apr 11, 2008 at 10:58 PM
RIGGERR1
The codes were checked but as stated in post, it came up as 02 sensors 1 and 2, and catalyst insufficiency, or am I checking the wrong codes? Is there some other code or engine flash light to check?
Apr 12, 2008 at 12:24 PM
BMRFIXIT
  • 19,053 POSTS
get the codes and I will run them down for you
auto zone will sacn it for free
Apr 12, 2008 at 12:46 PM
RIGGERR1
ok, I'll get that done on monday and post it. Thx.
Apr 12, 2008 at 1:21 PM
