2002 Dodge Intrepid left turn signal
72,000 MILES • 6 CYL • 2WD • AUTOMATIC
LARWIL
Left turn signal doesn't work even though I changed all the light bulbs.
Jan 4, 2009 at 6:42 AM
  • 110,251 POSTS
Hi:
Does it do anything... flash quickly, light but no flash...?
Jan 6, 2009 at 2:32 PM
LARWIL
It doesn't do anything.
Jan 8, 2009 at 1:03 PM
  • 110,251 POSTS
Hi:
If the fuses and the bulbs are good, you will need to check for power to the signal switch. To get to it you will need to remove the steering wheel and if it has an air bag, I recommend having a certified mechanic check it. The air bag can be deployed and then you have a more expensive repair.
joe
Jan 8, 2009 at 1:18 PM
