2002 Dodge Intrepid How to change
152,000 MILES • 6 CYL • FWD • AUTOMATIC
COBIRAY
Can you give me a step by step process on how to change my front brakes. To what type of tools I may need and the type of brakes that I need to buy because I am tired of having that brake dust. Thanks for all your assitance, Jacobi Criswell
Apr 14, 2009 at 9:55 AM
BLUELIGHTNIN6
  • 16,542 POSTS
We have a great step by step instructional video on replacing front brake pads and rotors. You can check it out at https://www.2carpros.com/car_repair_video/how_to_change_brake_pads_rotors.htm . You may want to consider purchasing a set of brake dust shields for your wheels to protect against brake dust.
Thanks for using 2CarPros.com!
Apr 14, 2009 at 3:10 PM
CARADIODOC
  • 34,413 POSTS
Be aware you can do a lot of damage from doing a brake job on your own. This is where training comes in. In particular, NEVER NEVER EVER push the brake pedal all the way to the floor. There is a very good chance you will destroy the seals in the master cylinder.
If you found really cheap brake pads that don't make visible brake dust, the rest of us would like to know where you found them. Might as well get used to cleaning the wheels because high-quality linings make dust.
caradiodoc
Apr 15, 2009 at 6:07 PM
