2002 Dodge Intrepid Hot Temp Coolant In Overflow Bottle
2002 DODGE INTREPID
56,117 MILES • 6 CYL • FWD • AUTOMATIC
INTREPID04
Hello I Just Changed The Coolant In It Put 50/50 Ready Mix From Peak, Still Havin problems of Over Heating The Coolant bottle Fills up And Makes a Boiling sound I Have Heat So The Thermosat Is opening Right ? I Opend The Nipple At The Thermosat To Let The Air Out Of It And Waited Till The Coolant Came Out Have i Not Done Some Thing Right ?
Sep 17, 2008 at 4:30 AM
BMRFIXIT
  • 19,053 POSTS
Replace thermostat
and check coolant flow
run engine and then let it cool off recheck coolant open bleeder and top off as needed
have a headgasket test done
good luck
Sep 21, 2008 at 10:16 AM
