2002 Dodge Intrepid Engine won't rev up
126,000 MILES • 6 CYL • 2WD • AUTOMATIC
WRIGHTGC1
I recently changed the water pump and pasenger side head gasket on my 2002 intrepid with a 2.7 liter engine. After every thing was put back together the engine starts up and idles fine but will rev up to just under 2500 rpm and die down, then back up to just under 2500 rpm and die down, and so on,
with the pedal to the floor. What could be the problem with the engine not reving up all the way ?
Sep 18, 2008 at 6:48 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like you missed the engine mechanical timing. either a cam is out of time or the crank is out of time to the cams.
Sep 18, 2008 at 1:06 PM
