Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Intrepid
Engine
Symptoms
Overheat
2002 Dodge Intrepid Engine Overheats when air condititionin
2002 DODGE INTREPID
89,000 MILES • 6 CYL • FWD • AUTOMATIC
BRFREE
MEMBER
1 POST
What would be some causes or the main cause of engine overheating when the a/c is turned on. The engine does not overheat otherwise.
Oct 17, 2009 at 3:43 AM
BMRFIXIT
Experienced Mechanic
Coolant fan operation
start engine and put AC on
does the coolant fan turn on if not check fuses ,relay and coolant fan motor
Oct 17, 2009 at 7:35 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
