2002 Dodge Intrepid engine light
THART42748
Engine Mechanical problem
2002 Dodge Intrepid 6 cyl Automatic 111000 miles
the check engine light will come on but before we can get it somewhere to be checked it goes out...also we were told we needed to replace water pump so we did cost us $850 dollars now we are having several leaks transmission fluid,antifreeze and oil any suggestions?
Feb 28, 2008 at 5:27 AM
BMRFIXIT
  • 19,053 POSTS
check engine light : PCM should keep in memory why the light was on
have it scanned for codes
as for water pump get another estimate
bit hi for me
good luck
Feb 28, 2008 at 10:15 AM
