2002 Dodge Intrepid
KENKUSH
  • 2002 DODGE INTREPID
Engine Performance problem
2002 Dodge Intrepid 4 cyl Front Wheel Drive Automatic
The car will be running fine, and then it will start rising the rpms real high, and then stop and run fine. When the car is idling it will idle fine and then race up to like 3ooo-4000 rpms and then idle back down. Any help with this would be apreciated. THANX
Tuesday, January 26th, 2010 AT 8:22 AM
  • 109,885 POSTS
HAs the check engine light come on? It sounds like there may be a problem with the throttle position sensor or the idle air control valve. However, I need to know if the light has come on.
Friday, January 29th, 2010 AT 10:41 AM
