2001 Dodge Intrepid wont start
113,000 MILES • 6 CYL • FWD • AUTOMATIC
CHARLIEP
this car is not getting fire hook up on a scanner said the crank shaft sensor so replace it and the car still wont start it gets fire every now and then but still wont sart put a cam button in still have the same problem so do you have a suggestion
Feb 16, 2008 at 12:43 PM
BMRFIXIT
  • 19,053 POSTS
what engine you have in it (engine size)
check timing belt
check /replace ASD relay
when cranking using scanner read data
do you have a sync between crank and cam
let me know
Feb 17, 2008 at 12:42 AM
