none of the windows will work..checked the fuses it isn't that
Oct 10, 2010 at 11:48 AM
✓Experienced Mechanic
Check if there is power to the main switch on the driver's door. If there isn't, check where the wiring goes through the rubber boot between the door and the door frame.
