2001 Dodge Intrepid SOME KIND OF PROBLEM
17,800 MILES • 6 CYL • FWD • AUTOMATIC
CHICAGO24
  • 7 POSTS
I have a 2001 Dodge Intrepid, 2.7 liter, automatic transmission and 189,000 kilometers. Today when I was backing out of the driveway it went into reverse fine. When I went in drive all the lights on the dash, REVERSE, DRIVE, PARK, were all on. And when I drove my odometer wouldn't work and it wouldn't go into the next gear.I take that back it pops in to frist gear after i let off teh gas but after that it will not go in to the other gears. I know this car has a lot of senors and i trying to find out should i get the sensor replaced or the whole transmission NOW I HAVE TAKEN THE CAR TO AUTO ZONE AND THEY HOOK IT UP TO A COMPUTER AND IT CAME UP WITH SENSOR THIS SENSOR THAT SOME IN THE TRANSMISSION AND SOME IN THE ENGINE. I JUST GOT THE ENGINE FIXED AND I HAVE RESET THE BATTARY. NOW WITH THE COMPUTER GIVING ME THESE CODES AND THERE LIKE 10 OF THEM NOW WOULD THAT MEAN I HAVE TO REPLACE THE TRANSMISSION AND I FOR GOT TO SAY SOMETIME WHEN I DID DRIVE IT IT WILL CUT OFF BY ITSELF AND IT WILL START BACK UP. codes P0700 & P0715
now i have change the input and the output speed sensor and i am having the same problem. now what do i check for now.
Mar 18, 2010 at 2:01 AM
  • 110,248 POSTS
I would recommend having the vehicle speed sensor checked. I believe that is where the problem is coming from.
Mar 18, 2010 at 3:09 AM
CHICAGO24
  • 7 POSTS
EVEN THOUGH I HAVE BOUGHT NEW ONES AND REPLACED THEM ALSO?
Mar 18, 2010 at 3:12 AM
  • 110,248 POSTS
That is what the codes are suggesting as the problem. If you replaced them, check for breaks in the wiring, bad connections, corrosion...
Mar 19, 2010 at 5:33 AM
CHICAGO24
  • 7 POSTS
DO YOU THINK IF I REPLACE THE TCM WILL THAT WORK
Mar 19, 2010 at 6:39 AM
  • 110,248 POSTS
It may, but before you spend the money, you should have yours checked to be sure it is the problem. A TCM isn't too cheap and I would feel better if it was checked.
Mar 20, 2010 at 5:02 AM
CHICAGO24
  • 7 POSTS
I KNOW HOW TO TAKE THE TCM OFF THE CAR BUT WHERE DO I GO TO GET IT CHK OUT?
Mar 22, 2010 at 1:37 AM
  • 110,248 POSTS
Some parts stores can do it or auto electric stores should be able to do it.
Mar 22, 2010 at 2:37 AM
