2001 Dodge Intrepid pcm was bad dealer said had a p1388 cod
150,000 MILES • 6 CYL • FWD • AUTOMATIC
EEZEDET
replaced pcm , new cam sensor still does not start, using my ob2 tester i get a read out that says module $18 is not responding. i know this is a factory id number do not know what it means. the 2.7 liter 2001 intrepid, no other trouble codes are present except the 1684 which is battery disconnect on this make. do you know if module 18 is the pcm...
Mar 30, 2008 at 2:26 PM
  • 75,988 POSTS
Have you check what's missing Fuel or Spark what is the code/s that your OBD2 tester pulling out from the PCM
Mar 30, 2008 at 9:15 PM
