Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Intrepid
Trouble Codes
P Codes (Powertrain)
P1800 - P1899
P1899
2001 Dodge Intrepid netural saftey switch code p1899
2001 DODGE INTREPID
210,000 MILES • 6 CYL • FWD • AUTOMATIC
RDBODY
MEMBER
1 POST
where is the switch located and do I replace it or is there a common problem with them.
Jul 7, 2010 at 4:59 AM
BLUELIGHTNIN6
Experienced Mechanic
the neutral safety switch (AKA Transmission Range Sensor) is on the transmission valve body manual valve shaft and will need replaced.
Jul 7, 2010 at 11:33 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
