Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Intrepid
Engine
Symptoms
Misfire
2001 Dodge Intrepid MISSFIRE
2001 DODGE INTREPID
150,000 MILES • 6 CYL • FWD • AUTOMATIC
IAMSAM5555
MEMBER
1 POST
HAD ENGINE REPLACED AND EINGNE INTERMITENTLY HAS MISSFIRES REPLACED ALL PLUGS COILS AND BOOTS TRIED NEW COMPUTER AND STILL MISS FIRES EVERY 7SEC'S
Sep 28, 2010 at 6:19 AM
Experienced Mechanic
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Sep 28, 2010 at 2:24 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
