2001 Dodge Intrepid Misfire, cylinder #6
138,000 MILES • 6 CYL • FWD • AUTOMATIC
WAYNE EBER
  • 5 POSTS
Check engine light on, code P0306 and P0306pd. Replaced sparkplug ignition coil, and spark plug. Runs fine, but then after running awhile, shut-off, then restarted starts mis-firing and continues until shut-off. Starts next morning with no problem, however, this am started and problem continued. I'm guessing an injector but do not know if an injector shows as a misfire code? Waiting your answer. Thanks
Oct 3, 2008 at 6:47 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:3fa912a31a="wayne eber"]Engine Performance problem
2001 Dodge Intrepid 6 cyl Front Wheel Drive Automatic 138000 miles
Check engine light on, code P0306 and P0306pd. Replaced sparkplug ignition coil, and spark plug. Runs fine, but then after running awhile, shut-off, then restarted starts mis-firing and continues until shut-off. Starts next morning with no problem, however, this am started and problem continued. I'm guessing an injector but do not know if an injector shows as a misfire code? Waiting your answer. Thanks[/quote:3fa912a31a]
Yes, if a cylinder is misfiring no matter the cause it will set a code. That is why I usually suggest starting with a tune up Plugs, Wires if look brittle, cracked or have more than 100k miles on them. Then check coil, injectors and injector harnesses.
You said you replaced the Coil Pack and Plug, did you check the plug wire?
Oct 3, 2008 at 7:00 AM
WAYNE EBER
  • 5 POSTS
[quote:190207b318="obxautomedic"][quote:190207b318="wayne eber"]Engine Performance problem
Check engine light on, code P0306 and P0306pd. Replaced sparkplug ignition coil, and spark plug. Runs fine, but then after running awhile, shut-off, then restarted starts mis-firing and continues until shut-off. Starts next morning with no problem, however, this am started and problem continued. I'm guessing an injector but do not know if an injector shows as a misfire code? Waiting your answer. Thanks[/quote:190207b318]
Hello, Engine does not have sparkplug wires. Signal to sparkplug coil, then down a rubber tube with a wire inside to top of spark plug. The tube and wire are part of the sparkplug coil.
You said you replaced the Coil Pack and Plug, did you check the plug wire?[/quote:190207b318]
Oct 3, 2008 at 7:14 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Oooppps,
Sorry, bout that guess when your working on vehicles, and answering questions in the forum here just becomes habit when checking things.
Check wiring to coil.
Oct 3, 2008 at 7:36 AM
