2001 Dodge Intrepid Evap System Leak large code p0455
180,000 MILES • 6 CYL • FWD • AUTOMATIC
DKILLACAMARO
can Evap System Leak large code p0455 Set off ASD?
cranks but dont start starting fluid will make it fire but as for running only starts with camshaft sensor unplugged runs good when unplugged for being in limp home mode long cranking to start 2500rpm max iv tested the voltage output on cam crank throttle ASD battery alt grounds etc. checked out alright have not tested fuel pressure assume its up if starts and runs with plug exception any help would be great Thanx
Oct 8, 2010 at 9:10 PM
  • 110,251 POSTS
The code at hand deals with an EVAP issue. A large leak is usually the result of the fuel cap being off, rusted holes in the filler tube... Start with that because you know that is a problem. If you can't find it, they are hard to see, have the system fogged. They will actually pump fog into the system and where ever the leak is, the fog will come out.
They don't seem related, but could be. I recommend starting there.
Oct 9, 2010 at 3:55 PM
