2001 Dodge Intrepid engine wont start
20,000 MILES • 6 CYL • 2WD • AUTOMATIC
RAIDERSACE
my 2001 dodge intrepid 2.7v6 wont start. i did have to replace the water pump and i also replace the head gasket and replace the crank and cam sensor on it too. i am only getting spark on one cylinder which is the passenger middle cylinder. i got new spark plug and check all the coil boots and they are good. i am only getting voltage to that one cylinder.
Nov 1, 2010 at 11:55 AM
  • 110,248 POSTS
Have you checked to make sure the crank sensor is good? Have you checked to make sure the wiring harness to the PCM is not damaged or loose?
Nov 5, 2010 at 6:34 AM
