2001 Dodge Intrepid Code P0601
BSCOTT157
  • 14 POSTS
Computer problem
2001 Dodge Intrepid 4 cyl Front Wheel Drive Automatic
My check engine light came on. I ran a diagnostic scan and received code P0601. Int Memory Control Bad Memory Check Sum. What does this mean and how can I fix it? Is there a problem with the computer itself or is this a relatively easy repair?
Aug 24, 2009 at 2:16 PM
BLUELIGHTNIN6
  • 16,542 POSTS
you will need to have the powertrain control module (PCM) replaced.
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_869.jpg
Aug 24, 2009 at 2:33 PM
BSCOTT157
  • 14 POSTS
Does this mean the computer is bad? I have always known the computer as the ECM. You are referring to a PCM, are these one in the same? If not, where is the PCM located so I can replace it? If the computer itself is bad where is it located on the vehicle? Thanks, Brian
Aug 24, 2009 at 2:46 PM
BLUELIGHTNIN6
  • 16,542 POSTS
yes, the computer is faulty. ECM and PCM are one in the same . electronic control module or powertrain control module, both refer to the vehicle's computer. it is located on the left side of engine compartment.
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_129.jpg
Aug 24, 2009 at 2:52 PM
