2001 Dodge Intrepid clyinder misfire
FREEAGAIN
  • 2001 DODGE INTREPID
  • 6 CYL
  • FWD
  • 75,000 MILES
The car is putting out codes 202 and 302. This only happens when the car is cold and the problem goes away when the engine warms up. I have replaced the spark plug and coill for that clyinder. Any ideas as to what to check next
Monday, June 21st, 2010 AT 9:45 PM
P0302 -Check compression and injector for cyl. No.2
The causes of a P0202 engine light code could be any of the following:
Bad injector. This is usually the cause of this code but doesn't rule out the possibility of one of the other causes
Open in the wiring to the injector
Short in the wiring to the injector
Bad PCM
Tuesday, June 22nd, 2010 AT 2:10 AM
