2001 Dodge Intrepid
92,000 MILES • 6 CYL • FWD • AUTOMATIC
TEW58
01 2.7 intrepid is leaking by the thermostat ther are 3 bolt holes connecting the housing about a 1/4 inch from the bottom bolt ther is another hole and water is leaking from there it is a drip drip drip. what is this for and what can I do to stop this leak
Oct 20, 2010 at 3:53 AM
WRENCHTECH
  • 20,760 POSTS
If this is the piece right in the front center of the engine, they are very notorious for those leaking. That consisted of a whole pipe that runs under the intake manifold. You have to get the part from the dealer.
Oct 20, 2010 at 5:24 AM
TEW58
on a 01 2.7 intrepid the thermostat is located on the side of the engine the hole I am refering to is just under it I'm guessing it is a weeper hole for the water pump I hope I'm wrong
Oct 20, 2010 at 9:45 AM
WRENCHTECH
  • 20,760 POSTS
No, I'm afraid your correct. That's what it is.
Oct 20, 2010 at 9:59 AM
