2001 Dodge Intrepid
RESENDEZ
Engine Cooling problem
2001 Dodge Intrepid 6 cyl Two Wheel Drive Automatic
My 2001 dodge intrepid, just started leaking anit freeze. It is spraying somewhere from the passenger side front. Not sure because I can't see the full radiator with the metal plate over it. Could this be caused from a hose, clamps, or the radiator itself.
Oct 6, 2009 at 1:41 PM
BMRFIXIT
  • 19,053 POSTS
You have to check
as all very possible to be leaking
coolant pressure test should reveal the problem
Oct 6, 2009 at 1:53 PM
