2001 Dodge Intrepid
CARNEIRO1964
Engine Mechanical problem
2001 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
why is my car knocking
Sep 19, 2009 at 2:55 AM
CH112063
  • 1,320 POSTS
If the connecting rod on the piston(s) is loosening up because of a bearing and oil pressure problem it sounds like a knocking sound. And low octane fuel causes the piston to hit the cylinder and make a knocking sound. They call that pre-ignition or fuel pinging and knocking. Sometimes it is hard to tell them apart.If its running too hot it will pre-ignite the fuel also.
Sep 21, 2009 at 11:50 AM
