2001 Dodge Intrepid
64,000 MILES • 6 CYL • 2WD • AUTOMATIC
JEFMON68
my signal works for about 3 or 4 cycles then shuts off while in the on position. i turn it off and back on and it repeats the process. sometimes it just stays solid. bhoth left and right. what part needs replaced and can i change it myself being somewhat mechanically inclined.
Jul 8, 2009 at 3:20 AM
  • 110,248 POSTS
I would start by trying the flasher. It's a cheap part and may be the problem. Yes you can do it. Check the owner's manual for its location. It could be under the dash or under the hood.
Jul 8, 2009 at 2:18 PM
JEFMON68
Thanks Joe... found it and replaced it.
I too like you enjoy giving FREE advice. btw - it is under the dash right next to the steering column. :)
thanks and have a great day!!
Jul 9, 2009 at 6:04 AM
  • 110,248 POSTS
I'm glad it took care of the problem. And thanks for its location. I'm sure it will help others.
If you have questions in the future, let us know, and thanks for using 2carpros.com
Jul 9, 2009 at 10:30 AM
