2001 Dodge Intrepid
108,000 MILES • 6 CYL • FWD • AUTOMATIC
RICKYRUMSON
I have a dodge 3.2 engine and and it does not heat up to the right tempature it under heats it self i also have another question when i am reversing at low rpms my car shuts off do you have any ideas what it may be thank you
Jan 18, 2009 at 5:47 AM
  • 110,248 POSTS
Hi:
I would start by replacing the thermostat for the heat problem (if you are refering to the engine not heating properly).
As far as the reverse, check for vacuum leaks on the engine and the hoses going to the trans.
jeo
Jan 20, 2009 at 11:40 AM
