2001 Dodge Intrepid
112,000 MILES • 6 CYL • FWD • AUTOMATIC
HAWKEYE115
have ignition problems checked cam and crank sensors,checked out ok. spark plugs fire on 1 and 4.might get a spark occasionally on another cyl.is it the pcm or should i look elsewhere for the problem.injectors seem to be firing ok.seeing that the car does not run,can the pcm be tested without the car,and if i need a new one,can it be programed out of the car.coils also checked ok.seems to be missing the firing signal on 4 out of the 6 cyllinders.
Mar 7, 2009 at 7:36 AM
ZACKMAN
  • 4,202 POSTS
Try something different. Pull your timing cover and check your timing. I am betting that you are one maybe two teeth off.
Mar 7, 2009 at 3:54 PM
