2001 Dodge Intrepid
94,000 MILES • 6 CYL • FWD • AUTOMATIC
BOB SCH
Camshaft Position Sensor Circuit Malfunction
Dec 12, 2008 at 4:05 AM
JDL
  • 16,098 POSTS
Should be located at the top of timing chain cover. Hall switch, three wire connector. Orange is ref voltage, blackwire with lite blue tracer is ground, tan wire with yellow tracer is sensor signal.
Because the crank and cam sensor share the same ref voltage and ground circuits, I'd check the circuits to both sensors. The info I looked at was for a 2.7 litre engine.
Dec 12, 2008 at 5:29 AM
