2000 Dodge Intrepid washer pump
177,777 MILES • 6 CYL • FWD • AUTOMATIC
RICKCLR
When I push the button for the washer fluid to come out, I don't even hear the pump and no washer fluid comes out. I want to know if it's a fuse and if so, which fuse it is or if it's the pump, can I replace it without replacing the whole reservoir.
Dec 23, 2008 at 10:51 AM
BUDDYCRAIGG
  • 2,262 POSTS
use a test light and check the plug for power at the pump.
if you have power, then the pump is bad.
you should be able to get just the pump
Dec 23, 2008 at 12:37 PM
