2000 Dodge Intrepid Turn Signal light trouble
15,700 MILES • 6 CYL • FWD • AUTOMATIC
SEBASTIAN_PERSONAL
  • 77 POSTS
I have this dodge intrepid 2000. I don't seem able to figure out what is wrong with my turn signals.
When I turn my signals on (right or left), it signals for about 10 seconds and sometimes less, then it stops doin the turning signals, then I have to reset the signals back to normal and do it all over again and it works for about shorter time. I don't know what is wrong with it. I check all the light bulbs and they are all in good condition.
I also put it in emergency signal and it does the same result. It turns on only about short of period of time and it stops.
Please help me explain the answer of my question and what should I do to fixed it.
Jan 1, 2010 at 11:57 AM
  • 110,246 POSTS
It sounds like the signal flasher is bad. One flasher runs the turn signals and hazard. It's located in the front seating area, driver side, under left hand side of instrument panel between junction block and brake pedal. Here is a picture for you to look at, but you will have to enlarge it to see it.
https://images.2carpros.com/forum/automotive_pictures/249084_flasher_1.jpg
Let me know if you have other questions, and the part is cheap and you can get it at any parts store. Joe
Jan 1, 2010 at 4:05 PM
SEBASTIAN_PERSONAL
  • 77 POSTS
Thank you soo much for the answer i need. My last question is, how much will it cost me and what is the name of the item again that i need to buy?
Jan 1, 2010 at 7:53 PM
  • 110,246 POSTS
It's a turn signal flasher. It should be under 10 dollars.
Let me know if you have any other questions.
Jan 2, 2010 at 6:46 AM
SEBASTIAN_PERSONAL
  • 77 POSTS
I would like to thank you for answering my question that I need to know. I haven't made an attemp of fixing it due to my schedule, but, i'll sure to asked you more question in the future.
Thanks
sebastian
Jan 2, 2010 at 10:23 AM
  • 110,246 POSTS
Not a problem. It is really nice to help good people like yourself. Thank you for using 2carpros.com, and feel free to ask any questions you have.
Jan 2, 2010 at 3:23 PM
