Welcome to the forum, maybe the flywheel has a bad spot on it? Did you try rotating the flywheel, then see if the starter would engaged? Some makes and models, the flywheel has a dust cover that you can remove, watch and see if starter pinion gear engages the flywheel. Not sure if that is possible on your vehicle?
SPONSORED LINKS
Monday, January 11th, 2010 AT 1:49 PM
