some times cuts off when mashing brakes?
CLEBO69X
going down the road, slow down to turn and mash the brakes the car will cut off, not all the time. what can i do to fix this , thank you
Mar 1, 2010 at 7:43 AM
More than likely you have a vacuum leak either in the intake or the brake booster that we need to find.
If you find no vacuum leak, then I would replace the brake booster because what is happening when you press the brakes hard is basically causing the engine vacuum to drop too low and this will stall the engine.
I am attaching the info below that will help with doing this.
Please run through this information and let me know what questions you have.
Thanks
Dec 15, 2021 at 11:53 PM
