2000 Dodge Intrepid SEVERAL PROBLEMS W/CAR
71,000 MILES • 6 CYL • FWD • AUTOMATIC
PHAYD927
Actually have several questions & need some prices..I am a female who knows very little..I have been having trouble w/ AC..keep putting free on in 1-2 cans then after about 2 wks have to put more in..Plus when I'm driving my car when I stop & it's cold outside (40 degrees) my oil light comes on & I know there is oil..Why is this happening..Also my heat is not working in the car!! What is the problem. I hope you can help me & if possible give me some prices on how much should be to repair..tHANKS for the info.
Dec 5, 2008 at 9:32 AM
BMRFIXIT
  • 19,053 POSTS
Sounds as if the AC system is leaking
and need to be check you keep adding freon is not a normal thing to do !
have to have it checked
add dye and check with black light for leaks
as for the oil pressure I would replace oil pressure switch as a 1st step
good luck
Dec 8, 2008 at 11:05 AM
